I am dismantling a spare trans-axle Conedriver gave me a few years ago. I want to get the Dedion tube all cleaned up and Powder Coated to substitute into my GTV6, but I've run into a very ticklish problem. The offset castings for the brake disk mounting are different for the GTV 6 and the Milano. I my picture, the tall offsets are from the GTV6 and the short ones are from the Milano Trans-axle. Does this mean the half-shafts are different lengths or the spacing from "back of the outboard hub mount" to "back of outboard hub mount" are different between the two cars. If so, there is no point in me getting the Milano Dedion tube all painted up. Who knows for sure. I may have some good Milano half-shafts for sale.
FYI: The inner circle of bolts are different too. The GTV uses 10mmX 1.0 extra fine thread grade ten hex-head bolt with a 15mm wrench head. Very difficult to find. The Milano used a 10mm X 1.0 Extra fine thread allen Socket-head bolt. The allen socket tool fits down in those holes in the offset piece. I guess you could use the socket head bolts on the GTV6 offste but you couldn't use the hex-head bolts in the Milano Offsets. Won't fit. My advise; Neverseize everything!
