1 - 9 of 9 Posts
The heater valve under the glove box in my '82 GTV6 is leaking coolant into the passenger side footbox. Anybody have one to replace or have a fix?
Thanks in advance.
GTV6 valve
Good luck Its easier to find a women that won't drive you crazy! But if you use a heater valve for an early MGB you can make it work..... Jim
Araknd,
I got a replacement diaphragm from scottsoldrubber.com.au for my Alfetta GT, heater valves for which are pretty much unobtainable.
Provided the diaphragm is the source of the leak (and unless there is a break somewhere, that is the most likely problem) the fix was straightforward. carefully drill existing rivets, separate halves, remove old, install new(noting orientation) and gently re-rivet. Was $25 or so for the rubber. I checked just now, and the part is listed under 'others'.
I've got an nos one with the tube that connects to the heater core. 100$ shipped in the usa if anyone is interested. Pm me.
Here is the correct link Scott's Old Auto Rubber
I see the part listed. Thanks for the lead.
Jaguar E-Type heater valve works very nicely and is cheap. Only snag is that heater valve is full open when the lever on the console says halfway.
Bye
Thanks, All! I have a replacement heater core with valve coming. If this doesn't work, then we will be trying out the other solutions you all have suggested.
Grazie. Ciao!
1 - 9 of 9 Posts
