Just for the records, it appears that the position of the central spline doesn’t contribution to the vibration as long as the tail shaft has been balance correctly.
The main factor which contributed to my tail shaft vibration is the mis-alignment of the crank shaft and gearbox input shaft and at the same time keeping the central tail shaft mount in its correct position.
Good luck and trust the info helps 🍀
