Hello everyone,
I'm in the process of replacing the inner boot of the driver's side CV axle, which had a rip. I read a number of posts here and found this video on YouTube that shows how to separate the joint from the axle (go to the 4:00 mark):
I tried to do the same exact thing (but am putting a piece of paper towel between the hammer and the joint to protect it a little):
Auto part Engine Automotive engine part Transmission part
Auto part Wheel Rotor Locking hubs Automotive wheel system
but the joint won't budge from the axle.
Does anyone have any suggestions on this particular step?
Also does anyone know where I can find the tool I need to crimp the clamps? (international auto does not have them in stock)
Water Circle
Thank you all in advance.
Igor
· Moderator
You have to remove circlip from end of axle before you try to remove CV joint. You need a pair of expanding snap ring pliers with pins to fit holes in circlips. Clean off end of axle to see it.
And if you find your replacement inner boot to small for GTV6 or Milano axle you can use a 164 inner boot. They will work on both inner and outer on those RWD axles.
No wonder it won't budge since you haven't even removed the back cover ;P Flathead screwdriver and hammer will do the job. Once it's off remove the circlip as mentioned before, now the cvj will easily slide off the shaft. While you are at it I would buy new circlips since the ones that are on gtv6 tend to deform while taking off, and may not fully engage in the groove afterwards.
Bringing this back from the dead. This is indeed my situation. Since it's not a traditional circlip, it's really difficult to remove without warping it, and if you do it will NOT reinsert, as the tolerance is just too tight.
Would anyone know the exact dimensions of the replacement part?
