1 - 2 of 2 Posts
The small shaft is spinning free of the driving wheel in my window regulator. Is the small shaft pinned to the driving wheel such that I could remove the mechanism and affix the shaft to the driving gear by replacing the pin, to get the regulator to work properly? In the picture, I am referring to the exterior shaft, protruding through the sheet metal. If you have any additional advice on window regulator repair feel free to respond. ('74 GTV 2000) Thanks.
1 - 2 of 2 Posts
