1 - 11 of 11 Posts
I am looking for a very good condition trans tunnel cover with the screw tabs intact - please see photo.
Thank you,
John
PM's Question.. John if you should have a red dot on your avatar in the upper right corner of your screen. Open the avatar by clicking on it and open "conversations".. The same is true for "alerts' which tell you there are posts on a thread you are following.. You can Unfollow a thread at any time
Hi Norman,
I did get a very quick response. I will keep your message in case.
Thank you!
John
Thank you, but I did find the part. If it does not look good, I will PM you.
Thanks very much,
John
Hi all,
Fwiw, for sending a PM to a person, you can also put your cursor above the avatar area of that person , a little screen will then show up spontaneously with some data of that person. At the under right side of that screen is the 'message' knob to click upon and you can start the conversation.
1 - 11 of 11 Posts
