72 GTV - In the photo is the tunnel collar that I took off the car yet it is very tight going back on and does not sit flush on the tunnel. It may be the new 2 piece rubber tunnel cover that I installed.
Is there a rule of thumb with the 2 piece and 2 separate piece rubber covers? I took mine apart over a year ago and do not remember what type(s) I took off. I just want to make sure I have the correct sequence.
Thanks!
Thanks! The fit is OK in the front but not as good in the back; maybe a quarter inch off the tunnel. I did cut away some insulation so the collar rested right on the tunnel.
