1 - 2 of 2 Posts
I have a problem with my GTV. MY right back tires sticks out more then my left and I think it's messing with my left runs.
Is this a common problem? Is the diffferential offset? Any help?
GTV differential offset
No, there isn't any differential offset and yes, it's a common problem when the two cone-shaped rubber bushings that attach the the diff to the t-arm go bad. Also check the t-arm washers at the body pivots. Both are available from the usual sources.
1 - 2 of 2 Posts
