1 - 11 of 11 Posts
I didn't know if they made a left or a right handed Qaud emblem for a 1969 GTV. If so which way does the stem face back or front?
Gregg
I think they're both the same
I bought two of the serpents less than a year ago and the green has already faded and fallen out of parts of the serpent which are left and right. Had to buy some Testors green enamel and VERY carefully fill the empty parts back in. So far it's holding in and not fading. I'f I'd have known how inferior the product was I could have just used my old ones with the Testors modle enamel. I would think the Quad would be much eaiser to refill with good enamel if one is so inclined.
If emblems are the same does the driver side Quad stem face front or rear?
Thanks, It looks that way to me also driver front and passenger rear.
There's a post called Badges(I can't figure out how to link it into this post), that covers this topic quite nicely. I always thought that the stem of the quadrofolio pointed forwards on either side. And I posted pictures from a catalog showing this.
There IS a difference between the left and right badge. However, it has nothing to do with the direction of the stem. It's merely the curvatures are different to lay flat against the contour of the c-pillar. I bought a set from Black Barts at the convention and it's obvious once you do a test fit.
Brad you are right they only fit one way. Here is a picture of finished product. These were the original to the car emblems that I had gold plated.
1 - 11 of 11 Posts
