1 - 5 of 5 Posts
I am putting together a 74 GTV that had factory air conditioning. The AC bracket, bolts, belt pulley, etc. are gone. Can I use the AC bracket, mounting bolts and pulley off any 2L (e.g. Berlina, Alfetta, Spider, etc.)? Or were these specific to the GTV?
Also, I heard/read that a better option might be a bracket and pulley off of an S3 Spider. Any advice on that?
Thanks!
I would be interested in the bracket if Scott doesn't take it.
I have a 74 US GTV with spica.
Thank you,
Glenn
Regarding the S3 (Bosch EFI), the compressor is mounted where the Spica pump normally sits. If you're running carbs that could work but you'll need the front cover from an S3 motor as well.
Darn...I am running SPICA. Looks like original for me then.
1 - 5 of 5 Posts
