Hi,
Does anyone have pics or info on the mounting brackets/ hardware that is used to attach louvers on a GTV-6? I have the louvers and nothing else! Thanks!
Louver attachement
If you are talking about the high mounted side louvers-There are three threaded attachment screws protruding from louvers that get inserted thru matching holes on body-Nuts are used from the inside to secure to body. I think they use an 8mm wrench-very cramped to get nuts started on forward ones. Other two way easier. Hope this helps-Cheers
