1 - 2 of 2 Posts
Hello everyone. I just found a nice looking Alfa GTV 2.0 V6 TB and I am pretty satisfied from the overall condition. What I want to check is for the engine's weak spots and usual weak spots. In general what to look for in the engine that usually wears out and should be taken under consideration. Every info on these things is welcome. Thanks for your time mates.
I have placed a lot of miles on these engines, not sure there is a weak spot. Stumbling under load? If running a little rough and the spark plugs have not been changed recently, that would be the likely cause. The maintenance schedule shows 20,000 km between plug changes. Timing belt life, I am not so sure about, as always, a concern.
1 - 2 of 2 Posts
