1 - 10 of 10 Posts
Hi Everyone,
I have a replica '74 GTAM that I'm currently working on. What options are there in terms of brake calipers that I can use to avoid any scraping in the inner wheel portion of a 13" diameter GTAM wheel? What are the choices I have? Any aftermarker calipers that are bolt on?
Any help is highly appreciated.
Thank you!
since you are fitting 13 inch wheels I presume you drive under historic rules? i so the only option is the one that is in the homologation, the aluminium ATE calipers. Are in reproduction now, or buy used ones from a Porsche. Use the search function. You will have top use smaller diameter disks and os on, the complete kit, disks, brackets and calipers is around € 2000,-
Caliper options
Thank you for all your help!!! I will go ahead and check your leads to see which way is best to suit my purpose. Thank you!!!
brake calipers
Let me check with my mechanic. I believe they were off a '67 VW bug. They had to fabricate an adapter for it. I will post pics. when the suspension is all detailed and sorted.
1 - 10 of 10 Posts
