1 - 11 of 11 Posts
Hi,
I have a pair of GTA push buttons and finally it is time to put them on the car! In order to do that I need to see which modifications that need to be done on a lock (something has to be welded) and on a passenger door (mechanism to close the doors from the inside).
I obtained various explanations already, however, a picture would probably be the best.
Could someone help me and send me a picture of this welded part as well as a shot of the mechanism?!
Thanks in advance!
Hi,
Thanks in advance!
Putting up the same question - how to lock the passengers door? When I bought the car, there was a piece of wood jammed between the pushbutton and the mechanism to block it - maybe not the most practical way. Any suggestions?
Any ideas? ?
Note my "like" on the photo with the fiberglass door. Similar to the mechanism used by Ferrari on the '65 275 GTB trunk mechanism. Finger loop outside and all. However, the Ferrari push button has a center KEY hole, and the push button itself can be locked with a key. I do not have a picture of mine handy, but the only difference is the locking button. If this is NLA, a brass button could be machined and made to lock with a simple or more complex key, then chromed.
Not an inexpensive fix, but locking doors would be possible. Why though if the car has sliding plex windows?
Your right, with the windows surely no obstacle for somebody willing to open it. It’s more a psychological question that not every spectator passing by is able just to push the button and to open the door.
I don’t know about GTA’s but on my 74 GTV, pulling up on the interior door opening lever locks the door from the inside, or maybe push down, but moving the lever in the opposite direction of opening would lock the door. Will check function on my GTA jr when I get home.
Passenger side button linkage
When I added loops and buttons to my '71, I skipped the inside passenger door lock linkage. Looked as though it would take more construction skills than I had.
I purchased a second keyed button.
Richard
Colorado
Richard
Colorado
Exactly what I did, and sold the "none keyed" button on.
Finaly I foud a solution - I bought a used GT mechanism and fittetd it to the existing mechanism. Now I'm able like on a standart GT to lock the door with the lever.
1 - 11 of 11 Posts
