541 - 560 of 570 Posts
Discussion Starter · #541 ·
Well it’s been too long away, but I’m back in the game again!
Off with rear wing and repairs begin on b-pillar.
1656110
1656111
1656112
Good to see you back at it - thanks for the update.
Reactions: BigMart
Discussion Starter · #543 ·
Ok it’s time for the c-pillar repairs.
These are pretty complex and to get to rusty part A, you need to hack out rusty part B and C....and maybe D! 😀
anyway - here’s what we started with and cut back to.
1658138
1658139
1658140
Discussion Starter · #544 ·
So cut away and remade the inner C-pillar panel. Still some weld tidying to do.
1658141
Then the inner arch to cut out and make a repair panel.
1658143
1658144
Then the middle panel repair section is made. Needs a bit of tweaking and welding in (I ran out of time to complete today.
1658146
Then it’s the curve profile where trailing edge of rear side window sites...and then move down onto the suspension, wheel well, rear seat panel repairs 🤓
Heck
Nice work of course 👍
Reactions: BigMart
Press on our brave friend, press on....
Reactions: BigMart
More metal at the back than you had at the front so must be a piece of cake for you now mate .:):cool:
Discussion Starter · #549 ·
Yes - but it’s a bit complex.
The rear parcel shelf to rear window flange area looks a tricky one!
I know mate I was just trying to give you an a r s e up compliment . Auzzie humour
Discussion Starter · #552 ·
Trimmed up the repair patch I made up last week and welded here in.
1659024
1659025
1659026
1659027
Started making inner piece. But will hold off on that as the whole lower windscreen edge /parcel shelf area has holes all the way along.
I will save this repair until the car is back on the rotisserie and access will be easier. I can flip the car 90 degree and work on it without craning over the rear wing and boot/trunk.
1659034
Discussion Starter · #553 ·
Today’s project, aside from fixing my air compressor, was to modify my mig trolley to accept a tig welder and the extra gas bottle. Fancied try tig for a while, and a good quality used one came my way!
1660300
1660301
1660302
Reactions: PSk
Over the holidays I finally started the teardown of my rusty old friend.
The most used equipment so far had been the dustpan and brush - sweeping up everything that falls off when I exert any force onto bolts etc! :laugh:
Once its stripped then its off to the sodablasters.
Anyway - please see some photos of progress so far. front and rear running gear and interior/glass left to do.
Front lower corner virtually non-existent!
Front anti-rollbar mounting and rail rusted away
right rear
left rear - axle strap mount rusted off
left side
right side footwell and sill/rocker
I'll be posting some photos soon how I repaired the front chassis as new parts aren't available
Discussion Starter · #555 ·
Hi Glynne, Im way past that now as my thread started about 5-6 years ago! :)
I got some NoS stuff for various models and made them work for me.
Gonna be working on o/s rear suspension mount area,wheel well and panel under rear seat over the holidays. Did the n/s in lockdown pt 1.
Will be tracking your progress. keep up the good work
Discussion Starter · #556 ·
Nice to be back in the workshop making some noise!
Today was ‘cut out and remake lower inner rear wheel well and under seat panels’ day.
1664107
1664108
1664109
1664110
Inner well piece was pretty easy to make. The under seat panel a bit trickier.
1664111
1664112
1664113
Ready to tack in. A job for another day.
Reactions: PSk
Discussion Starter · #558 ·
Time to tackle the rear suspension turret/chassis area that has rotted away!
1665344
1665350
It’s like peeling a rusty onion. Cuts back three layers and build back and weld in new piece .
1665347
1665348
Axle strap area next....
Reactions: PSk
Discussion Starter · #559 ·
Removed the axle strap hanger. Not to bad behind there. The bottom edge was rusted out so cut out and patched. One area had a small rust hole and the other area damaged when pulling spot welds/bracket off - so cot those areas out and rewelded new metal.
1665498
1665499
Reactions: PSk
Discussion Starter · #560 ·
Rear wheel well repairs done.
An internal rear seat patch to make, then it’s time to weld on the classic Alfa arch repair section...and fit rear wing. Yeehaa!
1666109
