521 - 540 of 570 Posts
Discussion Starter · #521 ·
Reconstruction under way.
1627895
Ran out of time to finish.
Strap mount all prepped and ready to go on also (not in pic).
Reactions: PSk
Discussion Starter · #522 ·
Finishing off the wheel well.
just the recess to make for the t-bar mounting bolt access - then we move onto the other side 😀
1628620
1628621
94529D48-0652-4C2C-B523-B8DD5BB1F8C5.jpeg 7E7E44E2-5849-434B-87CC-ADE8BD02A92C.jpeg 94529D48-0652-4C2C-B523-B8DD5BB1F8C5.jpeg 7E7E44E2-5849-434B-87CC-ADE8BD02A92C.jpeg
Reactions: PSk
Discussion Starter · #523 ·
Main repairs all done
Didn’t spend to much time dressing welds inside, as will never be seen - Just made them look ok from 3 feet!
1628859
1628860
530E81F7-F65A-4FAF-AAC5-90ABAE1CE8FF.jpeg 69398043-B93C-4BCA-86C1-260D11498418.jpeg
Nice work! I hope you find this (as I did) to be the most enjoyable part of the car to restore. Not sure why that was, maybe because it is a small project in itself without too many other things depending on it to complicate things.
Discussion Starter · #525 ·
Thanks. Yes it’s a nice mix of fabrication and fitting.
I still have some repairs to make to lower rear arch wells - but minor patches.
I will probably cut the rear wing off soon as I have the classic Alfa wheel well/each piece to fit.
That may uncover some hidden horrors 😀
Discussion Starter · #526 ·
Moved to the rear part of the well.
Was going to patch it ....but it was so pitted I thought it might be quicker to cut the whole piece out make a new one. My most ambitious panel yet I think.
Actually not so hard - just a lot of hammer time!
1630449
1630450
1630452
had to make a new piece where boot floor meets the well.
1630451
1630454
548B6694-0350-408F-96B6-A0571E8DD6C2.jpeg 4CB9D8B7-FFB2-4308-B506-C81CA53AAF85.jpeg 9987F0AE-D4EF-4A40-81B1-20F6C3B728FF.jpeg 167C60F0-68B2-4EDC-B3C4-9FC8FFD2A1CD.jpeg B51423E4-4E49-49E9-BBAA-C8B97D46C16D.jpeg 06FB7CE3-D86B-486C-96C7-575F0D7613E1.jpeg 548B6694-0350-408F-96B6-A0571E8DD6C2.jpeg 4CB9D8B7-FFB2-4308-B506-C81CA53AAF85.jpeg 9987F0AE-D4EF-4A40-81B1-20F6C3B728FF.jpeg 167C60F0-68B2-4EDC-B3C4-9FC8FFD2A1CD.jpeg B51423E4-4E49-49E9-BBAA-C8B97D46C16D.jpeg 06FB7CE3-D86B-486C-96C7-575F0D7613E1.jpeg
Discussion Starter · #527 ·
Replacement rear wing arrived so decided to stick on the same side and finish this side completely, before moving onto the other side.
welded in the rear jacking point (not pictured) - note for next time: weld it on before putting sills/rockers in next time 😀
when I cut off the rear wing I got access to the c-pillar area that is rusted out - so started cutting that out and started making patch panels.
no before pic taken - but same condition as drivers side.
1632642
1632643
1632644
653B7B17-787C-45E6-95BE-72A5C756CE31.jpeg 1DD4F73F-EA16-4508-B285-DBC3CBA88B71.jpeg E17D530C-BCE5-4D0E-AFE5-90A2999323A5.jpeg
Reactions: PSk
Discussion Starter · #528 ·
Rebuilt the c-pillar area. Tried to replicate as close to original as possible.
Left a load of metal on the seal flanges - so I can shape more accurately once the rear wing is fitted.
1633836
1633837
I tried not to go made on making it perfect as these areas never get seen once car complete 0E585B22-A89C-4F06-84C7-A2B0CFA5D7D3.jpeg 139319B8-F18E-4111-8981-B10C23BD97C4.jpeg
Discussion Starter · #529 ·
B and C pillar repairs completed.
Trial footed replacement wing and all looking good 😀
1633980
1633981
next job fitting replacement outer wheel well And rear win
Discussion Starter · #530 ·
Trial fitted Rear wing
It was on and off at least 20 times!
Fitted window and trims to check that was all ok.
Then fitted the replacement inner well part and finessed it’s got to the tub and wing.
Didn’t spark up the welder all day! 😀
1636022
Discussion Starter · #531 ·
Inner wells welded up and seam sealed - ready for final fitting of rear wing. Chuffed 😀
1636258
1636259
919F751A-D1B6-49AF-9263-217AED569407.jpeg 6848CDB0-F51E-44B4-BC6F-4C6C9B4D22F8.jpeg
Hi Mart I remember when you started on your car, and I admire how much you have done. Doing the back much be so much easier than the front, with all the fresh air you had at the front.
It was fascinating watching you over come the challenges you had there. Still watching and appreciating the work your putting in. Regards John.
Discussion Starter · #533 ·
Thanks John
yes there is a lot less going on at the rear too!
I feel like the end of the body work phase is in sight.
Still got the same amount of work to do on the other side rear quarteR, but I am actually daring to think about paint now 😀
thanks for the support and comments
Discussion Starter · #534 ·
Before rear wing gets welded on thought I would patch the boot floor on that side (around petrol tank aperture) as I have good access. One down - two to go.
1638698
Discussion Starter · #536 ·
Boot floor petrol tank edges patched.
We migT NOW get that rear wing on!
1639362
1639363
1F10DA24-BDEC-43BF-87B8-007C71A417C6.jpeg 9BB7190C-2943-4676-A9E9-71A3AAE75BFE.jpeg
Discussion Starter · #537 ·
On at last!
The area where it meets the boot and rear panel needs some work - but pretty pleased with how today’s work went.
1640387
1640388
1640389
AE80861F-FEA6-4F4C-8F81-400346E6C4C2.jpeg E8262877-463F-4F70-BA80-3892EAB0C140.jpeg 99033FB8-6B6B-4D83-801E-78AE884521AC.jpeg
Starting to look like a car again :)(y)
Reactions: BigMart
Discussion Starter · #539 ·
Thanks, yes getting there!
A bit of door gap fettling then over to rebuild the other sides inner wells, suspension, c-pillar etc 😂
A couple of months worth right there!
Discussion Starter · #540 · (Edited)
1640687
1640688
Side all in one colour. Ready to move on. Fine tuning of gaps and doors can wait to the end and will do all in one go all around the car at the end I think
E0911952-8BF2-49EF-B4AC-77DA5CAF9A5A.jpeg 1DD364FC-C3BB-45B4-BCAD-281EF6FFE867.jpeg
