1 - 9 of 9 Posts
Hi,
Can someone please tell me the exact location for the 2 ground straps, one for the engine and one for the transmission? Car is almost ready to be started after 10 long years!!
Thanks for any help!
Chris
Hi Chris,
Congratulations on your progress! I know there is a ground strap on the right lower rear side of the engine (passenger side in the US) that connects to either the fire wall or the transmission tunnel. My son just tightened it up for me last weekend. I'll see if I can get more information or a photograph this weekend. I don't remember seeing a ground strap on the transmission.
I did notice that Classic Alfa has new ground straps for about $11 each and thought it would be nice to replace the 'old oily bent up' one with a new one; next time I place an order.
Photographs would be nice!
Mark
I'm interested as well. Pix would be great.
Mark, thanks for the tip on Classic Alfa having straps, I need new ones.
there is a ground strap on the right lower rear side of the engine (passenger side in the US) that connects to either the fire wall or the transmission tunnel... I don't remember seeing a ground strap on the transmission.
Yes, there is just one ground strap - the aluminum engine and transmission conduct electricity pretty well; no need to ground both. The stock strap is usually connected to one of the starter bolts, and to a dedicated lug on the chassis near the starter.
Not to take business away from Classic Alfa, but in the US, NAPA stores sell a braided ground strap that closely matches the one supplied by Alfa. I think it's the one at: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Electrical-Ground-Strap-Cables-Velvac/_/R-TWEVEL058116_0144566658#largeProductImageWrapper , but you may want to do a little more research to confirm that.
Thanks, Jay!
Hopefully the following two photographs will be helpful. I just slid the camera under the car for the 'snails eye' view. From the 'birds eye' view you may be able to extrapolate where the cable goes on the engine, just below the timing port window.
The ground strap that NAPA has looks similar except it is either Aluminum or tin plated.
Good luck,
Mark
I will say thanks as well...I had the same question!
The nice copper ground straps that Classic Alfa sells are about 1.5" too short for the Montreal. When tightening up the bolts, one end ripped right off the ground strap. I wrote CA to let them know the ground strap did not fit the Montreal. Also that the Montreal does not use a foot operated (pressurized) windshield washer pump; that it has an electric (Nippon) pump motor; mine leaks like a sieve.
Mark
1 - 9 of 9 Posts
