i got a 74 spider, it has not ever grind gears when i got it, now that i had the engine out and all rebuild, new clutch and pressure plate and throw out bearing,
all new down there, now it has a slight grind when shifting thru the gears, he re bled the clutch to make sure there no air, and still it does it.WHAT WRONG
if u shift slow and hesitate in neutral for a second then it is ok. IS THAT NORMAL
THANKS
IT IS 2000 velonce
THANKS
IT IS 2000 velonce
