1 - 10 of 10 Posts
Good used engine and trans, was removed out of a GTV that was wrecked. Has been sitting for years but turned over by hand easy. This was a running driving car it came out of but I dont know the whether the engine used oil or the condition of the syncros.front crank pully chipped too.
The engine is located in Santa Barbara,Ca,93103. Pick up would be nice but I will ship.
$800.00 plus shipping
No, I was thinking of it but i removed the plugs and sometimes carbon can fall on a open valve and prevent proper readings.
I'd do it if you wanted though
let me know
It would be a big help in the decision, yes.
I realize an engine sitting for some years may not give perfect results right off. Thank you.
So I blew compressed air through the intake while I turned it over to hopefully blow out any debris. First set of numbers are 60,90,60,100. Then I squirted two squirts of 20/50 out of a convention oil can in the cylinders to seal the rings and the numbers are 100,110,100,110
Hope this helps
Emilio
1 - 10 of 10 Posts
