So - next few pictures show how to disassemble the mirror without breakage. It was basically pure luck the first time when I detached the mirror glass from its backing plate - that adhesive is normally strong. This time around, I decided to do things properly.
First I tested the mirror for correct adjustment operation - better to know now than later - and for me, no go at all.
The switch has a rocker with brass rollers, and a 'joystick' with three silver-plated cones. These are a frustration to polish and reinstall (work on the floor, not on a workbench, or you'll never find the pieces again...) Very satisfying when the mirror grinds into life in both directions. I think these motors are always noisy. The switch is usually the part that fails first.
Behind the bottom of the mirror glass, there are several ridges in the plastic. Engage a screwdriver and rotate - the picture shows where - and the glass complete with backing plate prises off reasonably easily. Detach the wires from the heating element. There are rivets in the metal film - one of mine had torn away. I wonder if all 164 mirrors are heated - if so, I've yet to see one that works! I have some 'wire glue' (conductive adhesive) to use for reassembly. I'm not sure that soldering on glass would be a good idea, but that may work.
The mirror adjustment platform (including motors) has an obstinate plug. Either try to release clips while pulling on plug (and stab hand in the process), or break off one clip quite by accident and pry the plug out. Three small Philips screws secure the platform to the frame - it is a tight press-fit onto the pillars. I may yet take the platform apart to grease the internals in an effort to reduce the noise.
I cut off the plugs so that wires pull through the hollow bolt of the mirror hinge. I remembered reading that on the forum before - and I have replacement terminals (non-insulated and proper crimp) of the correct 'tab' style to fit within the original plug bodies. With a smug feeling of preparation, I continued.
Wires pull through - black earth wire first, then sheathed orange wire (for heating), and then remaining three wires are loose.
Screwdriver jams nut so that 13mm deep socket removes hollow bolt.
There is one melted-over tube that secures the two housing halves, so this has to come off - I find a screwdriver 'drills' the melted plastic away. The other four melted-over tubes fasten the internal structure to the housing - there is no need to remove the internal structure, so those other four 'meltings' stay untouched.
With support/triangle out of the way, mirror housing pries apart. Housing is glued together - so a judicious series of pulling and prying, followed by a few loud snaps, gets it open. I think opening it is mainly required for the hollow-bolt refitting. It would be quite OK to paint the housings in a glued-together state, but getting the spring and nut into place would be very fiddly.
That's about it - I painted all relevant parts plus a replacement door handle. Note that this 164 originally had black mirrors, so it was tempting to get out the semi-gloss aerosol can, but since they were previously-painted, I perservered and laid on a basecoat - a bit more thoroughly than the previous painters - I painted the inside edges of the housing. Things are not quite perfect - it takes a great deal of work to get the triangle curvature smooth: easy for this to be uneven. Any crack repairs must be feathered really well. I used a grinding wheel (that powder/glue was even harder by now. I think the powder contains glass beads.)
Just needs a clearcoat now - I have a replacement bumper to prepare for my other 164 and I'm hoping to clear that at the same time... hopefully tomorrow.
I guess that putting the wires back in may be fun, but at least it will be easy to polish the glass and apply Rain-X.
-Alex
-Alex
