Was #4 the last cylinder you tested? The battery may have been wearing down by then...
I get ~155 psi in all cylinders of our '84. Rebuilt engine well broken in.
A step above a simple compression test is to do a leak down test. That'd give you a good number for future reference (especially if you do the test every so oftne using the same tester). And, if there is a problem, it lets you know more precisely where (rings, valves, head gasket).
