I just drilled deeper in my stash and came up with these... 17mm hex 10 x 1.0... I'm 99.9% sure these are what you need. Check your bolt,ok? scroll
heck the bolt to confirm
I just drilled deeper in my stash and came up with these... 17mm hex 10 x 1.0... I'm 99.9% sure these are what you need. Check your bolt,ok? scroll View attachment 1612414 View attachment 1612415 View attachment 1612416 heck the bolt to confirm
Richard,
I dug out some 1300 and 1600 rods and measured. 1300 are 9x1.0mm and 1600 are 10x1.0mm!
Otherwise they look identical.
Thanks to Jim S. for straightening me out . I was 0.01% WRONG..which is equal to close except for hand grenades The ones I showed you are for 1600 and possibly above that.... I did scrounge some 1300 nuts 14mm Hex 9 x 1.0 in the same profile ... THE BAD NEWS IS I only have seven (7).. Isn't that always the case? I looked everywhere except my dog's bed... I have your Paypal and will refund it when we decide to . Let me know.
I can supply the eighth (1) 1300 nut if needed.
