Manifolds replace headers
The two-piece manifolds take the place of headers in the exhaust system. They connect to the twin down-pipes that merge just ahead of the first (smallish, flat) muffler. This down-pipe assembly is fabricated steel, and is part of the front half of an OEM-style replacement exhaust system. If someone has either used after-market headers, or Alfa veloce headers, you'll probably be best off to replace the whole front half as a single piece. I always try to get my exhaust parts from Al Cosentino at FAZA. Be careful when connecting the cast iron 'headers' (stock parts for normale) to the steel parts, so as to avoid cracking at the down-pipe connection flanges. Get everything fit together snugly before tightening anything, is my procedure.
Also make sure the down-pipes' protruding pipe 'lips' fit into the ends of the cast iron pieces.
