Hey guys,
We are doing a brake job on my Sprint, and removed the wheels, but can't seem to get the brake drums off to get to the wheel cylinders. We removed the two bolts/screws on the face of the brake drum, but the drum will not budge. Is there bolts/screws on the rear of the drum, or internally, that are holding the drums on? Thanks for your help!
Hi there ane not other bolt/screw except the ones on the drum face.
Usually I do this work with a wood hammer, knocking all around the drum moves and come out...
But sometimes this method doesnt work so you can use one of the special tools in the photos:
I like the puller set up, very clever. I'll bet the aluminum drum bonds to the steel hub in the center. Sometimes some penetrating oil and moderate heat can help free things up.
I did the slide-hammer trick 25 years ago on mine.
I talked to a mechanic at a brake shop and was told that, in the right conditions, older drum brake linings can swell and make the drum hard to remove.
