Background: I've replaced the front brake cylinders, rubber and steel brake lines and linings on my spider; I've had drums cut to spec.
Problem: I've bleed the two rear brake cylinders, the passenger front brake cylinder without any trouble. The driver's front cylinder does not bleed.
When I loosen the bleeder nothing happens. I've pumped my leg off, even installed a one-person bleeding system that pressurizes the system up to 20 PSI and nothing happens.
Clue: when I remove the driver's side brake shoes and hand-press the cylinder pistons, the bleeder works fine. With the brake shoes and drum on--NOTHING.
Clue: the cylinders are 1" units from Moss Motors, an Austin Healey part that is supposed to be interchangeable with our cylindes.
Any thoughts?
Best, Vince Coppola
Any thoughts?
Best, Vince Coppola
