Hi everyone,
I have some doubts about the Alfa Romeo badges for the front grill and the rear lock (Giulia and Giulietta Spider):
Is the diameter the same (55mm)?
There are some with smooth pins and others with threaded pins: the latter are said to be for the rear lock but, if you install the badge before mounting the lock, how should the latter be fixed to the lid?
Would anyone show a photo of how it should be installed?
Thanks in advance
Diameter is the same for front Giulia 105 and 101.
I guess it's the same for rear lock.
rear badge glued ? Pins with plastic ? screwed ? I don't know.
Great tip! I never knew how to look for those clips.
Merci....FWIW The rear ones are always better than the front ones for obvious reasons especially the OLDE cloisonne with the deep colors. I have filed down the studs to make them work in front. BTW I might have the spacing reversed in the previous post.. Moreover the old style MILANO ones run around 55 mm OD.. the ones without MILANO run about 54mm and the two posts are narrower.
