The main issue is making sure the ABS distribution block and pressure reservoir get bled. There's also no mechanical connection between the brake pedal and the brake fluid.
Mike, I can get the MultiECUScan Interface Tool Kit with adapters for $112 from Alfissimo. But re. the software, did you find the Free version satisfactory for the home DIYer or did you pay for the Registered version?correct, I did the bleed without the scan.
There is a program called multiecuscan which allows you to perform the operation with the proper adapter cables. I use it to reset the service interval during an oil change
This comes up when googling for "alfa romeo giulia brake bleeding" Just wanted to pop in and say thanks!bleeding the brakes requires to put the rear brakes in service mode (can be done in the infotainment), and requires a motive powerbleeder tool with the european attachment set at 30psi. I've done it on my Q4 with no issues
This was posted on a different forum:
"Put the car in brake service mode in the infotainment system. Disconnect the integrated battery sensor (IBS) then remove the negative battery connection. Then service the brakes. Reconnect the negative battery cable and then the IBS. Turn on the car, don't start it, remove brake service mode, start the car, turn the steering wheel full left and then full right, recenter the wheel, turn the car off and you should be good to go. "
This is the factory procedure, hope it helps:
I used ATE Type 200 when I did this on my previous 2017 Giulia , but for warranty purposes, I believe Tutela is the better bet.This comes up when googling for "alfa romeo giulia brake bleeding" Just wanted to pop in and say thanks!
As someone who just cooked a rear caliper this was exactly what I needed to know.
At the risk of reviving a dead thread, is there a preferred brake fluid that you use?
Using the MultiECUScan, what are the steps to complete the operation?correct, I did the bleed without the scan.
you don’t need MES to do the job, just put the brakes into “service mode” via the car’s infotainmentUsing the MultiECUScan, what are the steps to complete the operation?
