I need to buy a new tank for my 1750 Berlina. I’m trying to figure out if non 2.0l GTV tanks are the same as 1750 Berlinas and Giulias. Some suppliers in the US say they’re the same but other suppliers say they are not. My Berlina is also an euro model so I don’t need a bottom feed tank.
Don't know if the non-2L coupe tanks are the same, but if you can't find a 1750 Berlina tank, and 2000 Berlina tank will fit, it's just a slightly deeper tank, so no doubt you'd have to also fit a 2L fuel sender etc.
AFAIK, up to the 2L cars, the tanks were all the same capacity, the 2L were larger.
Coupe, Spider, Berlina were the same capacity (although if you check Fusi, most were 46L capacity, then 2L range from 51 - 53L !)
I have an Australian delivered S1 1750 Berlina and i just replaced my tank with one from Classic Alfa. Fitted fine (would be the same as Euro spec).
Cheers,
Paul.
