I think you have a short or something in the microswitch. Although, I would think that the fuse would blow. Try disconnecting the microswitch wire at the connector on the right side of the engine compartment and check the light again.
If it's indeed a bad microswitch, just leave it disconnected until the next time you have the injecition pump off the engine. If it's properly tuned, you don't need the FCS circuit. Mines been inop for a couple years now.
