1 - 5 of 5 Posts
I am working on trying to figure out why when I shift from Park to Drive, the instrument panel says I am in 1st gear. Park and 2nd and 1st gear are correct, but all others are wrong. For a little while, they worked, now they are back to this problem. Any idea what this could be?
The indicator is a plastic part that fits in a sleeve under the cover (transmission console cover). If you pull off the cover, have a look underneath as the clear portion may be slipping.
Moderator
I think he is talking about LED indicator in instrument cluster not by lever in center console. That is electrically controlled by electrical switch on rear of transmission case.
1 - 5 of 5 Posts
