1 - 13 of 13 Posts
86 Veloce
Anyone else install a gear reduction starter? They sound like a helicopter starting.....
I put one on my '76 Spider. Much easier to install, no need for the front support bracket, weighs less, and the car cranks faster. What's not to like?
86 Veloce
All true but wasn't my point at all.
I don't know what a helicopter sounds like when starting up...? It must take a long time if the starter has to spin up those long rotors. Or is is quicker?
Mark
86 Veloce
That high pitched gear whine.....
I just put one on from Performatek made in England by Wosperformance..Sounds effortless and actually spins the motor rather than the tired OEM I had that sounded like... ahhh--------------ahhh-------" please don't try to start me!" and the engine had molasses in it. I'd never go back.
If you have a high compression motor, the gear reduction unit works much better than an old Bosch unit. Mine does not sound like a helicopter at all !
Richard Jemison
You got the wrong one for your flywheel. The position of the drive gear on the mounting nose is in a different place depending on ring gear tooth count.
It will eat up the teeth....
86 Veloce
Thanks Richard, I will check that out. I believe I ordered it from Centerline...
After 26 years in the USN and serving on 5 ships with embarked helicopters (SH-2Fs and SH-60Bs) I know well what a helicopter sounds like when it starts up. That as background, my Performatek gear reduction starter in no way sounds like that. As I've mentioned before on similar starter threads, putting the gear reduction starter in was easily one of the top 3 improvements I've made to my '73 in the 46+ years I've owned it.
86 Veloce
I too, spent much time on carriers and much time in LAMPS helicopters. I did some research and reduction gear starters with straight cut gears have a distinctive whine. I took the inspection plate off and inspected the ring gear, I see no signs of any damage. It does not sound like grinding for sure, just a whine. Engages, disengages, and starts fine. I will keep an eye ( or should I say ear) on it and inspect the flywheel regularly until I determine whether there is truly an issue....
I too am a fan of gear reduction starters. Alfa started fitting them to all Spiders in 1986 so they have been around for 34 years. My Bosch GR starter does not make a distinctive sound.
To inspect the ring gear. You will need to rotate it while looking at it.
Being a 4 cylinder engine. The ring gear gets mainly worn in 2 places.
1 - 13 of 13 Posts
