1 - 12 of 12 Posts
Hi, I have a 3 litre v6 12 valve engine and gearbox in my kitcar. I stripped it down and during the rebuild lost some gear linkages, can anyone help show me which parts i need to order please?
thanks
Phil.
Primary missing piece is the lever between the rod and the other shifter lever with the ball socket. Pics are below, as well as parts diagram. You're also missing the large plastic cover and two small metal clips that secure the cover to the trans case. Make sure you have both bronze bushings in place, on either side of the rod. The rubber cap and accordion boot on either side of the rod are NLA and are very hard to find in either good used or new variety, but those missing bits certainly won't keep the car from being 100% usable. Not sure what you're doing for shift linkage at the reaction bushing side of things, or for the shifter bushing fork where the shift lever connects to the rod?
1614253
1614254
Thanks so much, now I remember seeing it before I lost the **** thing. Any idea where I can get one, I've tried searching for that part number but haven't had any luck.
Thank you.
Prod. Code​
F.​
C.​
Modif.​
Qty​
N.​
C.​
C.​
R.​
1​
SHAFT​
7659951​
01​
2​
BUSH​
7659768​
01​
3​
ROD​
60510000​
C0101​
01​
60807743​
D0101​
01​
4​
BOOT​
7643303​
01​
5​
LEVER​
60800505​
C0101​
01​
60807729​
D0101​
01​
6​
LEVER​
5977148​
01​
7​
SPRING​
5978698​
01​
8​
SPACER​
7554971​
01​
9​
BUSH​
7643300​
01​
10​
BUSH​
7643301​
01​
11​
BOOT​
7643302​
01​
12​
PLANE WASHER​
10516679​
01​
13​
LOCK WASHER​
13507011​
02​
14​
LOCK WASHER​
12601274​
02​
15​
SCREW​
10902217​
02​
16​
SCREW​
16043324​
01​
17​
SCREW​
16044024​
01​
18​
NUT​
16104111​
01​
1614289
item 3 and item 5 matched set it seems with production change D0101 that occurred with chassis 62332147 and up takes item 5 60807729 lever and 60807743 rod.
164 Early chassis # less than 62332147 use the C0101 part numbers. I don't know the difference.
Yes, any idea where I can buy them from?
Try asking APE in California. They deal in used Alfa parts of all kinds.
Let me know if you cannot locate these items. I would be glad to sell you these items. I have some good used shift rods, but not the rubber boots, unfortunately. I have a matched set of the number 3 and number 5 items that will work together. Just send me a PM and we can converse there.
Charles
The rubber accordion boots were available about a year ago when I replaced mine; thanks to help from Chris.
It is good to see Charles still checks in from time to time. He could use another 164 before the values really start to sky rocket, or not. Happy to vouch for him as well. He helped with several parts for my 164-S.
Mark
I should have them but have to dig them out.
1 - 12 of 12 Posts
