1 - 20 of 23 Posts
My gas gauge instrument lamp was out, so at night it was hard to tell how much gas I had. I had read up on replacing the bulb through the radio slot, or through the vents, but a lot of people seemed to think it was possible, but had not actually done it. So I did and here is a wee tutorial. My radio is after market and look a bit difficult to remove so I thought I would go the vent route and this turned out to be very easy.
First I pulled the directional cover out of the dash.
Then I pulled the hard plastic end piece up and forward
You then peel the rubber vent tube from the plastic end piece,and you can let it drop back into the dash, out of the way.
As you can see you now have pretty good access to the back of the gauges. This is the fuel gauge, and the bulb holder with the white wires is for the "Low Fuel Warning" light on the gauge. The bulb holders with the yellow wires are the gauge illumination lamps/bulbs
Next you can pull the bulb holders out of the back of the gauge, by twisting and pulling back on them.
Discussion Starter #2 (Edited)
Gauge bulb/lamp replacement Part 2
As to the type of bulbs I used 194 LL (Long lasting), but the std 194s would do.
The illumination looks about the same as the other existing gauges
just follow the reverse procedure to put her all back together.
what part?
why order a honda insight.,look at our ford fusion hybrid..much , much better car..handles like a sports car, can drive longer and faster on the electirc motor then the allmighty honda..
Yes but
I work for Honda (IT Department) :D
what part?
...ford..first on race day:D:D
My own experience... ford = found on road dead
Thanks so much for posting a novel way to access the gauge lights (this belongs in the sticky on the first page); I've been contemplating pulling the dash to get at them.
-Dave
Alfas
Heh Heh. At least we all agree on Alfas:D and even on the model:D
Discussion Starter #8 (Edited)
fog
Noticed that the Gauge was foggy tonight, common problem, but the fuel gauge, (I guess because of the lack of a working bulb for a while) seems to be foggier than the rest. I'll see how it goes before doing anything, because its been humid here.
I may experimnet with a hair dryer, and pull the bulbs, heat the front of the gauges and put the bulbs back in.
Gauges in dash
Hi Gadwhite
I'm thinking of mounting gauges in the vents just as you have. Can I ask you how you mounted them? What plastic did you use?
Many thanks
Simon
These comments are very encouraging and have lead me to this question. Now that I understand how it can be removed, how do I test my fuel gauge? If I need a new unit, whom do you recommend? I have an 85 Graduate and the gauge does not work. Thanks, Joe
First thing I'd suggest is to check the connections at the sender. You'll need to move the trunk carpet aside (it is glued along the top of the left edge under the weatherstrip so just fold it over the left rear fender). There might be a black plastic cover over a hole in the trunk floor - if so remove that. You can then see the top of the fuel outlet and the wire attachments. Some info here: sender wiring
If everything is connected properly but it still does not work then we'll have to figure out if the sender or the gauge is faulty.
For useful used parts try calling Alfa Parts Exchange.
Hello - Just read your thread on replacing the gauge bulb on a Spider. Looks easy enough. Where did you get the replacement bulbs. I am also located on HB down by Edison HS - Hamilton & Magnolia.
Ed
Discussion Starter #16
Bulbs
Ed
Got the bulbs from Pep boys over on Brookhurst. Bought them a while ago they are type 194's. Picture here
Discussion Starter #17
loaction
PS. Im over on Newland and Adams
Discussion Starter #20
Cars and Coffee
Nice!!!! We need to meet up! Do you ever go to Cars and Coffee in Irvine on Saturday mornings??
Yep, but havn't been in a while. Do you ever go over to Donut Derelicts, on Saturdays ( Adams and Magnolia)?
1 - 20 of 23 Posts
