All,
The question is, how to get sequential spark and sequential fuel running in the Alfa Twin Spark.
The reason why this is 'hard' is because there isn't a cam driven sync signal.
You need to tell your ECU not just where the crank is, but also when in the 720 degree rotation of the crank the crank is on the compression stroke for cylinder #1.
There are a couple options that I have found to get a cam signal.
There is an AEM EPM (Engine Position Module) which apprently can give a crank signal and a cam signal all from one device.
Has anyone used something like this?
Engine Position Module (EPM)
One other option is to keep my crank signal from the stock hall effect sensor.
And just get a 'home' signal from my distributor running off the oil pump.
Idea's for cobbling together a home-made solution for this:
DIY TCI + CDI Trigger Article
914World.com - The fastest growing online 914 community!
Anyway, was wondering what others have done to gets this signal and run a full sequential spark and fuel.
Ian
Ian
