My fuel tank is evidently killing my fuel pumps. I have another thread about this.
This car has been kept in a garage since new. However, it doesn't get driven enough. My bad.
Just looking in the tank it appears fine. I haven't scoped the whole tank but from what I can see with a flashlight it looks OK. I see zero rust.
Also, I stopped using ethanol fuel several years ago.
So I pumped the fuel from the tank and found that there was a greenish powder like substance in the tank. At first I thought it was just something wonky with the fuel.
So I pulled the tank out of the car. I bought two gallons of fresh fuel, poured it in, sloshed it around and then pumped it into a disposable cooking pan. The first time I did it it seemed as if about two or three tablespoons of that powdery like stuff settled into the bottom of the pan. So I put a filter into a funnel and pumped the gas back into the tank. The residual gas/powder in the pan was poured into my hazardous waste container.
I repeated this process 10 or 12 times. Every time the powder was less but it never stopped.
It does not look like rust.
Here is what I do not know. Does the original tank come with a coating on the inside? My best guess is that this powder is the original coating coming off.
So if that is the case it seems obvious that something needs to be done.
Here are my options as best as I can tell:
1. Have the tank boiled out at a radiator shop. This is a bit of a problem because most radiator shops have stopped doing this and the only one that I can find is very sketchy about the price. "Somewhere between $175 and $300." I assume that after this I would have to recoat the inside.
2. POR 15. I have used this product in the past on motorcycle tanks. It works great but is a big toxic pain in the tushy.
3. Buy a new tank. I see that Vicks Auto and Classic Alfa have tanks. I think I can get one shipped for about $300. Are they exact fits? Are they already coated on the inside?
Any advice is greatly appreciated.
