1 - 19 of 19 Posts
As I am going through the electric circuit of my car (rather easy with papajam's wonderful color chart) I have come to question my fuel tank sender (no reading from it).
I have dismantled it and have 2 qestions:
1. there seems to be current flow/contact issues. I will clean up the metal to metal contacts (wire brush-sandpaper) but should I plate/paint/coat the parts with anything to prevent corrosion ? (it should not corrode once dipped in gas - should it ?)
2. The finger that runs on the wired resistance seems funny (has a hole in it). Is this normal or is it worn down ? It should still work .. right ?
Roland
Discussion Starter #2
Fuel sender
I forgot.. I can probably repair it or buy a buy a new one. Could not find any new ones that looked like this one on my normal part suppliers. Anybody have a better clue than I ?
Roland
Roland,
It has been a while, but I seem to remember that there was a metal "brush" held in that finger.
In any case my sender was rusted solid, so I replaced it. The '69 units were NLA, so I bought the newer unit. The difference is that it has the fuel supply line running through it. I cut this flush with the top of the sender, and put in a brass plug. Looks pretty good.
I also added a separate earth from the sender, as rhe tank did not earth all that well after painting, sealing, etc.
It is great to be able to tell how much gas I have!
Marc
Fuel sender
Which one did you buy ? These are the ones I found ...
FUEL TANK SENDER - VEGLIA 006
FUEL TANK SENDER - JAEGER 007
FUEL TANK SENDER - 2000 TYPE
FUEL SENDER - INJECTION SPIDER
Fuel sender finger
You mentionned a metal brush.. i looked in my little pan with all the parts.. did not see any stuck inthere..... If I clean up the finger and other contacts I assume it might work... I'l try. But a new one might be a better solution in the long term.
Roland
As I said, not sure on the brush part, as I am going from memory.
I looked up the receipt for the part I purchased.
It was from centerline, part no: FL329.
Description: Fuel float spider 69 - 79 (modify for '69)
HTH,
Marc
I think that the missing piece is made of carbon. I extended the life of one like that by bending the wiper arm so that it made contact with the rheostat windings. It did not do much for the accuracy. I have a brand new sender for an '82 spider that I will sell for 50% of the IAP price. You need to check to see if it will fit.
Ed Prytherch, Columbia SC
Out of the office!
Sender
I'll try to find an old little electric motor and getthe carbon brushes out ans see if there is a way of hooking it up... or maybe if I put a spot of solder on the end of the finger ?
If not I'll go for a new one and plug the fuel outlet..
Carbon brushes are available for (for instance) starter motors. I purchased some a few years ago for a Spider starter that I thought was perhaps a little worn out. Turned out not to be the case, but the car and brushes both are gone now. But brushes should be available. Maybe someone will provide a picture of the unit as it should be?
Michael
Discussion Starter #13 (Edited)
Done !
Well I went the easy route. I put a tad of solder on the tip of the finger. First a ball (photo1) and then I thought I should enlargen the point of contact so I made a flattened glob (photo2).
I assembled the casing and made measurements. It seems to work great !!!
Not sure if these readings are any good but at least it gives me a reading. (shouldn't the "tank empty" reading be higher than 0.34 ? I tried it many times and it always gave me that precise reading).
Here is the first series that measure the gauge.
Discussion Starter #16 (Edited)
Fuel sender
This repair took mere minutes.. really no time.
< 5 minutes to take out of tank.
1 min to dismantle
< 5 min to understand how it works
2 minutes to clean
10 minutes to get solder hot and make fix
5 minutes to close up and test.
Total less than 30 minutes !
Hoping it will last.. time will tell. Contact against solder is probably really poor compared to carbon brushes, but what a fast fix.
By the way are these readings any good ?
Other point: when I tested the leads to the gauge I had 12 v in one lead and only 9v something in the other.. is this normal ? Maybe a poor contact. I'll check the leads next week.
Roland
Nice MacGyver repair!
Just as a point, you might want to get a line on a replacement sender. I bet the repair you've made won't last too many years...
Discussion Starter #18 (Edited)
Fuel Sender
I'll let the board know if it dies on me. Right now I have so many things on my plate that I am happy to have this quick fix in place.. If I ever get my hands on a carbon brush I will solder it or screw it on the finger... At least I can wait a while until I tackle the problem again...
Well, time to head to the next challenge :)
1 - 19 of 19 Posts
