1 - 11 of 11 Posts
I have an extra from a GTV6 2.5 12v engine. If that sounds like a proper replacement, you can contact me via e-mail. Can send pix if that helps.
Peter
[email protected]
Hi Peter,
Thanks for the reply, I already have the one you are describing, I am assuming it is the rail with the bends in it.
I am after the straight type with the regulator the bolts to the end of the rail.
Thanks Sach
Hi Sach,
No problem. The GTV6 rail is more of a U-shaped tube. I also have one for a 164Q V6... BUT that one is reserved for my slow moving 3.0 24v transplant into a GTV6.
Good luck with your search.
Peter
Hi, I have what you`re looking for according to your picture.
I`m going to send you a picture. Do you need Rail-injectors and regulator or only the rails?
Hi.
Everyone thanks for your help, I was a bit desperate for these bits, unfortunately all the stateside offers would take to long to get here, I'm moving house, so will have to get the car trailered and hope my fuel rails show up when I unpack.
Thanks again sach.
i have what you; need for v6 engine. NOS and may have used . get back with me and i will get pics and info
1 - 11 of 11 Posts
