L-Jetronic?
Your correct, the fuel pump should not run all the time.
From Bosch's Gasoline Fuel-Injection System L-Jetronic Technical Instruction booklet,
"The electric fuel pump starts immediately when the ignition and starting switch is operated and remains switched on continuously after the engine has started. A safety circuit prevents fuel from being delivered wehn the ignition is switched on, but when the engine is stationary (e.g. after and accident)."
this is accomplished via the Drive Relay, Tachymetric Relay, or Fuel Pump Relay. Pick your label, turn the key and the main relay turns on the Jetronic box which in turn turns on the tachymetric fuel pump relay for a moment to build pressure and give the system enough fuel to start. Anyway the tachymetric relay turns on and stays on once receiving a signal from the coil that the engine is running. Earlier S3s had an Inertia switch instead of or in addition to the Tachymetric relay so not so sure there but suspect the same problem(s).
Is this a long running problem, like since you bought the car or a new development?
Either way, under the rear shelf carpet on the passenger's side you will find the Jetronic controller, 2 relays (main - smaller & Drive - larger) and an altitude compensation device.
If a new problem, the relay is stuck on?
If an old problem, the relay could still be stuck on but there is a fair chance someone balked at the price of the relay or couldn't get one quick enough and jumpered the fuel pump on.
I guess the safety circuit in the L-Jet controller could have an issue.
the both relays are common and can be found from a few manufacturers.
tachy relay Bosch # 028230001, Beck-Arnley # 203-0100, Kaehler (KAE) # 3.304.500 (currently on sale at AutohauzAZ, stock # 13631276264 for <$25. You may want to confirm the #s and cross reference)
main relay Bosch # 0332014125
Rock Auto shows the Beck-Arnley part for a 1985 BMW 535i $42. That is what I bought a few years ago as I could get it the fastest. I think the brand was KAE? Worked fine until it went for a swim a couple months ago. Odd though, they dropped it from the Alfa listing?
You can google the Bosch # and should get several hits from BMW specialists.
