Ciao Alfisti!!
I recently replaced the rubber fuel lines in the car and decided to also add a proper fuel pump. The one that I ordered is the Facet that IAP has. I removed the 2 wire pump and the brace that is bolted to the car. I cleaned, replaced and mounted the brace and new fuel pump. In all the excitement, I forgot to note how the pump was wired. There is a Magneti MArelli "relay?" that is mounted next to the pump, there is a pink wire running into one side of it(which is power from the fuse box). The old pump had 2 wires, while the new one has just the one. I realize that the new pump grounds to the car-but where does the power wire go? Does it plug next to the pink wire? The marelli relay has 2 screws, as I said the pink wire goes into 1 screw. I hope this makes sense. As always I await your responses.
Thanks yet again...
Thanks yet again...
