21 - 25 of 25 Posts
Have you checked fuel pressure at the fuel rail? Make sure there is no fuel in the small vacuum hose between the Fuel Pressure Regulator & the intake plenum. If there is then FPR has failed internally.
I know this may be a little off topic but... Thanks to this thread I figured out that the fuel pumps running while they key was set to "on" was not normal. I spent a few hours reading the other posts, testing my relay, and I ended up ordering a Beck Arnley 203-0100 Relay as I already had the KAE variant in the car and it was not behaving as it should. After installing the Beck relay everything worked perfectly!
Thank you guys for you all you contribute to the community it really helps us newbies!
p.s. i have included some pics of the internal KAE relay if anyone is interested.
21 - 25 of 25 Posts
