happy new year. been looking at the forums for a while to help me out, but have run across a problem that is driving me nuts.. my car, 95 24v, stopped, started up okay, drove home and stopped again. Lack of fuel. Checked fuel pump, it's okay, as well as pressure. here is the issue. I try to start it and no fuel. Checked relay S12b, motronic with diode, and it works. Checked relay 12A, no work. Have power to pins 30 and 86. When I put my 12v test light onto pin 85, while the relay is still in the socket,the light lights up and the pump now works. previously, the fuses attached to the system, the 15 a and the 7.5 amp, didn't work, but when I put my tester on pin 85, both fuses now work, sending power to the pump. Has anyone run across this problem? I am guessing that I will have to dive into the motronic control unit. Anyone with thoughts? Any help would be appreciated. Thanks, John
