Hissing sound???
Ok, noticed on my '84 Spider... a Hissing sound from the engine compartment... am looking all around, notice the Fuel Pump Regulator bolt is lose, tighten it up, notice the hose that connect to the top of same, is showing some cracks... cut off the top 1/2 inch, reconnect... still hissing, not as loud, but still there... if I wiggle the entire regulator, the hissing stops/starts.... not sure if the hissing is coming from somewhere on the rail itself though, as I push the rail around, up down, etc... the hissing stops/starts as well... should I loosen that large bolt at the bottom of the regulator and then reconnect (sigh, if it were only to be that simple)... do ya'll think that there is a problem in the rail somewhere?
Anyone had this happen to them yet, what did you do?
Thanks folks, any advice/suggestions, as always appreciated... and again, am quite a rookie, so please bear with me. Lots to learn still... heck, only way I even knew that that thing was is because of the IAP "Whats that things under me hood" page.
