I want to replace the small fuel lines in the trunk of my 84 spider veloce with fuel lines from a local auto parts store.
Is there someplace that has listed all the separate hose sizes throughout the vehicle? If not, what are the sizes for the trunk fuel line?
Assuming the lines are the same between your 84 and my 87, I believe the supply lines to be 12mm and return line to be 8mm. In which case you will be stuck having to use 1/2" for the 12mm because metric is hard to find. 5/16" is more or less the same as 8mm.
