Just started to put in my refurbished rail and noticed I'm missing a PLASTIC PIECE that goes in the head. It is not the injector rubber seal. It's a Plastic Washer that the rubber seal sits in. Are these pieces available or do I just not use them? I looked at the usual vendors and no one carries them.
PLEASE HELP!!
Alfa Parts in Berkely CA may have them.
What you lost is a phenolic "cup" it is a kind of hard insert to hold the injector pintle tip and provide some insulation from heat.
It is important.
TTFN Elio
Greg, That's why there are 2 Rubber Seals on my injectors!!! I was going to call you about that. Yes I did check to see if they were there. I had 3 and I am missing 1. It probably fell in the motor somewhere. I looked and couldn't find it. I thought I might of sent it with the Rail, and I was was going to call you Monday. Thanks for the HELP! I'll just put it in with the 2 seals then. By the way I am very happy with the job you did on my fuel rail. Well worth the money.
