Does anyone know what the nut at the end of the fuel door cable is called? Trying to find a replacement online. My cable is good just the end piece broke and needs to be replaced.
1647409
If your talking about the piece in your picture.
Its called the fuel door cable. The ferrule is made onto the cable. So the whole cable has to be replaced.
It comes with the outer housing. Unless the outer housing has been damaged. You don't need to replace it. Just undo the cable clammp and the filler door latch and un hook the cable from it and pull the old inner cable out of the housing.
Feed the new inner cable into the housing by lifting the release latch inside the car. Then bolt it to the latch handle and reconnect it at the filler door latch and then your done.
