Free A/C from 82 Spider. Compressor pulley spins free and compressor shaft turns OK. Condenser with fan. Underdash unit evaporator/blower/x-valve OK. Was gas tight at dissassembly. Also odds and ends, switch, hoses, ducts, ect. Pay shipping from West Paducah, KY. Est $50.
think it will fit a 79 spider? If so, I will gladly take it!
Well, anything can be made to fit, but in the Bosch injected '82 the A/C compressor goes in the same spot that is used to for your SPICA unit... That said, there are SPICA Spiders which have been fitted with A/Cs...
Best regards,
I pulled the air pump off of the other side and was thinking of that avaliable space.....
I have seen A/Cs fitted on this side in series 2 Spiders (and also in factory installations of say a 1974 GTV)... You may also consider moving the battery to the trunk...
Best regards,
