First I do not have any DC03 Webers, No 750 intake manifold, and no cams.
Block was stamped AR 131 31209, not stasmped correctly at the Factory. Crank is in the block, no damage or corresion. Has the matching caps and chain housing. Steel Veloce sump with correct oil pickup , good head with the correct veloce plates , correct valve cover with the screws, water tube, oil filter and spacer, repaired and aluminized 750 -101 headers, Marelli Distributor, the Veloce intake side engine mount. Contact me at
[email protected]
FOB akron, ohio
regards, owen
other parts to be added 750-101 spider and veloce
[email protected]
FOB akron, ohio
regards, owen
