Moving, must sell!
1992 164s black with tan leather, approx 250k on body, 79k miles on engine (came from parts car: 164s, same year, same color, hit left rear)
Lots of recent work:
  • less than 10K since total brake job including all new rotors, new rear hard-lines, left rear caliper and parking break cable
  • 20K Since New radiator
  • Professional rust repair on both rear fenders with metal/fiberglass and new paint
  • Front fenders, headlights, grill and hood from parts car installed (southern origin, excellent paint)
  • new power window regulator
  • less than 5K miles since new muffler
  • trunk lid and spoiler from parts car installed
  • spring from parts car installed left front (replaced broken spring)
  • less than 50K miles since new windsheild
  • new head gaskets
  • new timing belt and tensioner (just done!)
  • new radiator hoses
  • recent intake flex-pipe, K&N filter
  • recent front suspension bushings
  • side mirrors from parts car installed
  • Engine runs strong and smooth, no visible smoke from tailpipe when you mash it (and it IS fun to horse arround a bit ;) )
  • Eclipse AM/FM CD, Canton 6 1/2" seperates in the front, Polk Carbon Coax seperates in rear (kickin' stereo!)
  • lots more little stuff!
Known problems:
  • Speedo does not work, probably the wire got damaged during the engine swap
  • Power steering rack leaks fluid at about a quart every 300 miles, rack on parts car is good.
  • Oil presure reads low at iddle, its a bad sender, pressure reads 20-25psi at idle hot and 60psi at 3500 RPM hot when measured with an external guage (with 10w40 Mobil-1).
  • Alarm/keyless entry has a short somewhere and does not arm, unless disabled alarm drains battery.
  • Pasenger side front power lock non-functional (parts car has good doors on passengers side)
  • Rust on right front jack-point needs repair
  • ABS light on, parts car has complete system...
  • Active suspension defaults to sport about 70% of the time (proably a bad wheel sensor (did I mention the parts car?))
  • AC blows only a little cooler than the incoming air, should recover with a recharge (compressor, expander and condenser on parts car!)
  • Needs some love, and a good detailing!
All this plus a parts car of the same year, model, and color AND a partial parts engine (if you want it)!
Altleast 11 good Speedline/Alfa 15" alloy wheels, mabe 12 if the left rear from the parts car can be straightened.
Must sell because of moving, I won't have a place to park it and I can't afford to transport it and store it.
Parts car MUST go away with the good car, I don't care what gets done with it, but part of the deal is that the buyer makes it go away :) (the parts car will need to be towed on a flat-bed as the left-rear suspension is crushed)
Runs and drives great!
Asking $???? MUST SELL! No Reasonable Offer Refused!
Pictures below! Ask if you need more!
Call or e-mail Matt Wimmer:
days: 802-734-6794
e-mail: jawzxx *at* gmail *dot* com
Still for sale...
the car is still available, it's been crazy arround here moving and tryong to live in two places at once...
Will post some pics, hopefully this friday.
pictures, finally...
jeeze it's been crazy. Didn't even have time to wash it, but here are some pics of both the good car and the parts car.
I don't want to put this on ebay...it needs a good home! Make an offer, will anyone buy it for $2500?
