its an 1987 1.5 twin carb with about 35,xxx on the engine and most upgrades and about 2 years on the paint job... all receipts available
when i bought it about 4 years ago it was a different colour, had some minor body damage and some rust... this is a rundown of everything done recently
ENGINE
Rebuilt heads, new exh valves, Welch plugs, Thermostats, Waterpump, all hoses, Coolant system flush, Cambelts, Alternator, Pertronix Electronic ignition (Bosch distributor) and coil, Magnecor leads
FUEL SYSTEM
Re-kitted and tuned Carbs, new cotton braided fuel lines, fuel filler hose, BMC air filter
DRIVELINE
Clutch, 4 Gear synchros, Clutch master and slave cylinder, rebuilt pedal assembly, 4 wheel bearings, L/R inner half shaft bearing and seals
SUSPENSION
KMAC springs, Koni sport shocks (reds)
BRAKES
New front pads, brake lines
BODY
Resprayed in mid 2005, new rear window seals, rear hatch seal
EXTRAS (spares / bodykit neg dep on price)
Super Sprint Muffler, Rear mounted battery (high cold crank rating), Zender Spoiler (installed) Zender bodykit (unpainted), aftermarket seats (originals included), spare front and rear bumpers (inc brackets), Haynes repair manual, Mechanical and body part microfiches
there are two minor mechanical issues - the spedo and odo stoped working about 15xxxkm ago and the rear drums have glazed abit meaning some squealing when first used (car still brakes fine...and drums still have pad left even though glazed)
bodywork issues - there are a couple of small spots of rust that have appeared -all are minor and only one has really just started to crack the paint. they're easy fixes - there is no major rust anywhere in the car.
there are also two sections of weather trim that need to be put back on to really finish it off - i have the trim and even there rubber end caps
Essentially its a very good condition car - very well looked after and maintained... i would not hesitate to drive it anywhere - hopefully someones is on the lookout for a good one!
All inspections are welcome and encouraged - i can be contacted at lucas DOT anderson AT internode DOT on DOT net or gimme a call on 0409498077 in the evenings
$5000 AUD ONO
