I was replacing my front brakes and I had a hell of a time removing the passenger side rotor... once I got the hub off the inside bearing was still stuck on the stub axle. I tried everything short of a torch and eventually using a puller I got the bearing off... the driver's side slipped off like butter. I'm assuming the stub axle on the passenger side is bent so I'm in the process of locating a new knuckle and I think I've found one.
I've read my manual on replacing this part but I'm looking for suggestions and warnings before I begin. It looks to me that placing a jack under the front spring perch should allow me to unload the knuckle so I can remove and replace it. true?
-Raffi
-Raffi
